brobertov8
Hi All,
Please I really need your help to solve this problem.
I was thinking the EGTS (exhaust) sensor was bad. Just replaced it today. But the issue did not goes away.
When I went to ride I got A-TEMP warning, plus limp mode, every single time I pass 4000 rpm...
The ski was not perfect before, but I was almost solving all the issues on it.
It was running very fine, and I only got A-TEMP warning before when I was running above 6500rpm.
But I did something wrong
I went to test it last week and I forgot the "valvule in an exhaust cooling hose" closed... Result: the exhaust went to a high temperature fast.... it reached 279F degrees "max temp" on candoo...
I realized something was wrong but just riding for about 2 or 3 minutes with the valve closed, until I realized there was something very wrong .... And so I waited to cool and open the valve ... (I just removed this valvule this week... I did not like that for sure....)
But unfortunately I am finding that I blew the waterbox or something. Because now the ski is worse ... I am having high temperature exhaust even before 4000rpm .... And the performance of the ski is worse, no doubt!!!.
Please, what could happened??
Checking candoon MIN/MAX exhaust temp and realize that the problem is really high exhaust temperature (numbers are in celsius).
If it is the waterbox, what could have happened? And how can I fix it? What is inside of it that may have broken?
You can touch the JPIPE any time you want, even with the A-TEMP alarm sounding... Almost sure it is low temp.... Problem seens to be from waterbox to forward...
Thank you for any help!
