I goofed up winterizing
revereamg
i have a 1999 gti with a 717. when i was putting antifereeze into the motor(thru the water exit hose), i pinched the engine drain hose (clear drain hose coming out of bottom of exhaust), but i forgot to pinch the engine water supply hose (on rear of motor, arrow points into engine).
the antifreeze went into the drain hose like the manual said it would.
But, did me forgetting to clamp the water supply hose let the water/antifreeze go somewhere it shouldn't ? (like the exhaust or the cylinders) Would it be ok to leave it like this for the winter or do i need to re-winterize it ?
No - you're good. The clamping is meant to ensure your antifreeze goes everywhere you want it to go. but this event did not result in anything disasturous.
