Hi Guys
I saw a thread in the how to section and was wondering if you guys could help.
I have a 1995 Seadoo HX which has big problems starting.
THe ski wont start either warm or cold without alot of cranking / choke etc, i find that once it starts if i can jump on and take off it will generally run and go pretty well until i stop and then it will either stall or when you hit the throttle again it will stall.
The compression of both cyclinders are 120, it does still have the grey fuel lines, which i will be replacing over the weekend and trying that.
Is 120 too low compression and could this be causing the starting issue, or do you think it is definatley a fuel problem?
Thanks
Matt
Thanks
Matt
