So...I have two new (old) skis...a 1996 HX and a 1998 XP Limited. I have rebuilt the carbs in both. I *thought* the 1996 HX (tock 717 motor) was good. I ran 3 gallons of gas through it on the first ride and it ran great. Today was the second ride. The first 20-30 minutes the ski ran great again. Then it started having issues. At first it seemed like it was loading up with gas and running super rich. Then it would lean out and run fine. Then as I was going wide open down the waterway the motor would suddenly lose all power then surge and take off again then lose power then surge again. Seemed like it would lose fuel then pick it up again, then lose fuel, then pick it up again, etc. When I slowed down it seemed to load up with gas again. Wouldn't idle either but that may have been the idle screw adjustment. I brought the ski home and removed the air box and "filter" so I could see down into the carb bodies. When the ski is running and I rev it up it seems OK but when I let off the throttle I can see a squirt of gas going into the carb body on top of the closed butterflies on both carbs. When I see the squirt of gas the motor runs super rich and loses power.
Any idea what is going on? When I bought the ski the previous owner had this "bogging" problem but convinced me it was bad gas and the carbs just needed cleaning. Do I have two bad carbs? Did I do something wrong in the rebuild? I used a genuine Mikuni rebuild kit and new Mikuni needle and seat in each carb. I checked the pop-off pressures in both carbs and they were right according to the chart on this site. Those dang little rubber grommets and round thin check values were a pain. Maybe I messed them up??? Everything else seemed to go smooth on the rebuild. Why was it running great then all of a sudden this problem?
