hull swap questions
marlboroa
ok i have a 97 sp that needs alot of cosmetic stuff and a new impeller and wear ring. I am getting a 97 spx that is complete except for the engine. i want to put the engine from the sp into the spx. what all do i need to swap for this to work. I know the mpeg would need to go with the motor since they are different sizes but what else. also the spx has no title so what could i do about that. would it be legal to swap the vin plate or is that a bad idea.
Not a good swap. They have different motor mounts. You will need to use all the electrical, fiberglass in some motor mounts, and swap the impeller.
ok well now that i have it here, its missing way to much stuff to try this. now is there any way to test the mpem on this ski or do i have to take it to a seadoo dealer?
