I have my '02 Utiopia blocked up to do some work and was underneath today, waxing the hull. I came across a section between the keel and the side, about the center of the boat, port side, where the gelcoat appears to flex in about a 1/4". When I push it in, I can clearly hear a squishy, water sound. The section that is affected is about 1 foot high by 2 feet long. No cracking or blistering of gelcoat that I can see. I suppose water could have gotten in from the top by rain....it has not been covered for a while. But the compartments drain to the bilge, which has been pumping out regularly whatever doesn't go out the drain plugs. I have heard the cores on these boats are foam, not wood. Is that true? Does anyone know if the stringers are plywood? I wonder if a catastrophic failure is possible if I do nothing. I wonder if this could have been a production error where a void was left by accident. Cutting the boat apart at this time is not financially possible. Thanks.
Mike
Mike
