Huge Boobs Small Bikini!!!
OK.... FIrst... I'm pissed off. It's early... I'm drinking my coffee, and I don't see any boobies :rolleyes:
Just an FYI... most people will click on this thread, and then close it once they see it has nothing to do with the title.
Also, you would get more answers if you posted in the proper section. a) you have a boat, not a PWC, so put your questions in the boat section. b) you aren't having "Trouble" in the initial question. So put it in the general section of the boat forum.
Now... to give you an answer:
Yes, your ride plate is the plate extending under your pump. It controls the attitude of the ride. If you push it down a little, the nose will drop in the water at high speed. If you lift it... it will come up. Some people like to run an extended plate, for more control... or bolt on a plate with chines in it, to help the ski hook up in a corner.
Drifting under power is normal. You have 2 engines spinning the same direction, so you are fighting torque. Your steering problems is the same thing.
If you have any other thoughts, or questions on this... post in the right section, and you may get some answers.
