On the tank bottom is a large oil line that routes to the lower rotary gear bath nipple under the rotary valve cover, then is pulled thru the
engine by gear bevel action and is pushed out the exhaust side of the engine and dumps into the top of the oil tank, unless someone has
removed the tank, tied the two lines together. NOT a good idea, as a small amount weeps into the crankcase past the crankseals on each
side of the gearbath cavity.
On the tank bottom also is a small oil line that goes to an oil filter, then to the oil injection pump that mechanically mixes the precise amount
per the RPM thru two 3/32" oil lines, one to each cylinder gas-air rotary valve lubrication nipples that introduces the pressured oil into the lower cylinder cases to lubricate the crank bearings, cylinder walls, piston & rings. These two small lines become brittle, or break, so people
MIX, instead of replaceing the lines every two years. If you ever owned a weed-eater, you know they fail after age. MIXING is a PAIN, but
its one or the other. maintain/replace the oil lines every two years OR remove the injection pump and put on a block plate, so the RV gear
will not become damaged by free-wheeling in the bath cavity, clamp off your small oil line that went to the injection pump and then pre-mix your oil/fuel. A down side is if you idle around a lot, the *plugs fowl as being oil rich.
