semperfish
Alright, brand new to SeeDoos and sight. First post from Tampa FL, live on MacDill AFB. I traded for a 01' GTX DI red/blk. It runs great with 202 hours on it. All I had to do is replace battery and steering cable. Now the questions: I can't turn Left. I took it out for a test spin and noticed it makes sharp rights but no Left. I believe the problem is at the nozzle end, right? Do I undo the threaded metal eyelet piece that screws on the end of the cable to make it longer or something? I will try to experiment but, I need a rudder steer (pun intended) in the right direction. What do I mess around with.
The paint is slightly faded, what product/process to bring it back to a high gloss. I have heard buffing, wet sanding, then waxing, and a couple others. Is there a rub on/ rub off compound?
I noticed there are two white plastic wing nuts in the middle on two screws, not sure what these do? Doo you? The screws are just about shot/ what part number are they. It looks like they are the only ones that have a wing nut like that and they are right out in the open.
Whenever you hook it to the hose and run it on land, the say start it up first. Then no longer after 5 sec. turn on the water. Wouldn't that hurt the impellar if it is running dry, even so short? I would rather have the water first, but they are talking about blowing seals.
It also has a bad rattle when idling on land. It stops when you gun the throttle, and when it is in the water. Problem? or just wear and tear.
I was thinking about some bottom paint to protect the bottom. It has been rubbed down to raw fiberglass in about a 1/2 ft area and scrathed bottom. Should I worry about it? Not for looks but so the bottom is protected better for beaching the craft on beaches?
What is the recommended tune up I should do if it has been sitting for a while, ie, fuel filter (does it have an oil filter that needs changed?) spark plugs, flush anything? or if I took it out and besides the steering issue, if when I gunned it, it took off pretty dang good, would you say get some use out of it.
Sorry so long, but I had a lot of questions. Thanks for the help. Looking forward to meeting a couple of See Dooers here in the Tampa Bay Area. We hit Beer Can Island quite a bit since it is so close. If you ever see a whit Correct Craft Fish Nautique named Semper FIsh, or see the red/ blk See Doo, stop and say hi. Check out my youtube
http://www.youtube.com/user/gigg566
