How do I remove gauge cluster in 2002 gtx 4tec and how to seal from moisture
Alangsam
I appear to have the dreaded 2002 2003 gauge cluster complete failure. How do I remove the cluster.? How do I prevent moisture from getting in the new cluster?
The cluster is mounted in a rubber seal. It just pops out. The replacement cluster is of a new design for better venting.
When you say it just pops out. I just pull from the front? it looks to me like you have to take out the black plastic under the "hood" first to then get at the gauges? do i have to unscrew all of the bolts on the underside first?
Yes, you just pull from the front. There are no screws or bolts to take out. Take a flat blade screw driver and gently push it in between the side of the gauge and hood...... then pull back at you. Do the same for the other side. I know it looks difficult but it's easier than you think.
