shockerfd
I know, simple question right? Hot exhaust might usually point to a failing cooling system. The reason I ask is that after 3 blown engines, I'm beginning to wonder. Yes, carbs have been rebuilt and gone back over by Seadoo. Boat has been switched to premix. When things were running well and after running, the exhaust was cool enough to touch. Normal. Boat runs normal temp and rich looking plugs. Then another time out boat runs lean and exhaust is sizzling. Everytime the engines seized, the exhaust pipe was too hot to touch. Now I have seen water flowing out the tell-tale on land and in water, so I'm assuming all is well there. Now, can a lean condition be caused by cooling system not working or do I still have a fuel problem that's blowing my engines? Will a lean condition cause the exhaust to run hot? thanks
