hi guys, i need some help troubleshooting an issue on my 1995 GTX. I replaced the malfunctioning fuel baffle with a used unit, containing a new float from OSD, and it would appear (via an ohm test) that it is it is providing an accurate fuel level (~3 gallons); however, I am still getting a red light and no bars on my gauge. I have jumped the gauge circuits and the gauge reads full (bars).
At this point i think I have established the following:
1. the baffle & float are good
2. i have connectivity from the baffle to the gauge
3. the gauge display works (i.e. all bars show up when jumped)
could it be:
1. the fuel gauge dose not register under 3 gallons
2. the gauge may not be working right (unable to read tank level even though display works)
3. some other reason
I know it would be easy to add more gas and eliminate one of possibilities, but I'd rather not have to siphon the tank again (if i need to pull it to remove the baffle again)....i just got back eye sight after the last 2 times
Any help would be greatly appreciated.
could it be:
