I will try one more time for some help. I have two 06 rxp 4tec supercharged. One of them is having a bit of a problem. When you gun it from a standstill the rpm's just sit there and bounce of the rev limiter for about a 10-15 sec delay then finally it goes. My other one grabs right away and nearly throws you off and it will go 70mph no matter where your trim is. The one with the problem will barley hit 70mph only with the trim all the way up. I just had it out this last weekend and now it is starting to stink like maybe its building up carbs or getting a little to hot but the indactor has never came on. The one with the problem did have its impeller changed out last year by an authorized dealer due to it sucking up a rock but I am assuming the same was put back in. Other then that, that is all that has been done too them. Please help any ideas or test to do would help me I am new to these kind of powersports. I am wanting to learn. thanks
