RESTO Help removing a gasket
MoDawg73
Hello all, I am rebuilding a 951 and I am having trouble removing a gasket from the exhaust manifold. I don’t want to use a razor so as to not gauge the surface. Any tricks? Thanks,
Ken
i first use a razor blade to get the big chunks off, then i go to this to clean it up. never had an issue.
Be careful with the wire wheel. If you use too coarse of one you can actually damage the gasket surface.
