They are 5/8 Hex. Is it possible the socket is not deep enough? Look down the hole, if the hex is not rounded out, your socket is not deep enough.
The socket is deep enough. I just got back with a new set of tools just in case. Tried 14, 15, 16MM. Brought 17 but it's too big for my deep drive socket, I'll replace it for the right one. Also, tried 18MM the other day but it is way to big.
I'm sure it's touching bottom, I can tell (feel it) especially with the drive of course. The socket by itself would not be deep enough.
At first I thought the previous owner bought some different types of plugs (not 5/8), but after trying so many different socket sizes, I don't think this is the problem anymore. The reason why isn't engaging is that the plugs are too tight, too deep down, so there is no enough thread for the socket to engage, I believe. It's the only logical explanation. Remember, it is not that they are too hard to get them out, it's that they are not even engaging. When I turn the socket counterclockwise, it just spins and spins, not sound or feel of engagement... They're not rounded. I can see the thread on all 3 of them. The hex looks perfect.
Someone recommended to use a reversible driver, but for this to work I need to use a hammer. I don't want to use a hammer there and break more porcelain and go through the same again...
Unless 17MM works, I don't know what else to try. I haven't put any fluid in there yet, I was thinking to put some WD40, but again I'd like to see the socket engaging first anyways.
I got my new set of spark plugs just now and they are certainly 5/8, 16MM, both sockets fit there perfectly.
Thoughts?
