Help on impeller replacement
ChrisV
I am wanting to replace my stock impeller, it has some dings in it and Im assuming needs replacing...
So here are the options I have found.
1-Replace with another OE impeller -LINK-
2-Upgrade to this one -LINK-
So what do you think. It sounds like the Solas one will increase thrust over the stock impeller helping with accel and top end, what are your experiances with this
I have the OEM on my 95, make sure you have good compression before expecting a lot of big jumps in speed, your carbs and oiling must be in peek shape to get those lab tested results, I remember when my gtx was owned by my cousin the talk was the swirl prop, when I did a major overhaul I polished every piece of intake/prop as well as the air flow thru the engine and this made the difference for me, I tried hydrogen to the intake but saw no major increase - I think because I had all the surfaces so smooth already, 53-58 is my average the higher numbers are at daybreak on glass like water, cool air.
