alexandria
I know this issue has been discussed several times but what the ski is doing is somewhat different from other posts. This is forum has been very helpful in dealing with the Direct Injection model (very painful ski)
After riding it a few hours this season, the ski showed the MAINT with alarm every minute and RPM dropped to 4900 RPM. I started it several times with the same issue every time ... Suddenly, it's back to normal with no alarm or MAINT for an hour however, it reached 6900 RPM but there was some loss of power ( lag in getting up to speed after reaching a high RPM ... Next day, It showed the same issue again ( MAINT, alarm and low RPM 4900RPM, loss of power). Checked the impeller and was clear, Checked compression on both cylinders (130 / 127 psi) ..... I noticed that when you flush it, the engine hesitates and can stall every time I try to flush it with freshwater. Also, the drowning mode is not active on the ski (when you press the throttle fully, no alarm and you can still hear the fuel pump working)
Is it one of the Throttle Position sensors
Is it the Water pressure regulator
Any other suggestion PLEASE
I appreciate your help and support
