Donnerlakedoos
Hi all, thank you for many years of help, I've always been able to find answers here, hopefully someone can give me an idea of where to go next with this one. I've got a 2007 gtx 4tec standard that has been giving me trouble.
Symptoms: starts and runs great, fully charged battery runs 0 to top speed great. Somewhere around 10 to 15 minutes in the engine completely dies leaving me stranded. Insert key two beeps, solenoid clicks, no starter. Repeated attempts fail. After a tow home I removed the plugs, roll the starter motor over a bunch clear whatever is in the engine out insert plugs start engine runs great. 10 minutes in repeat process.
Action to date: took the Seadoo to the local dealer put it on buds, nothing. No error codes nothing showing. Nothing wrong they say since the comouter tells them so. Right? so Mechanic in me goes to work. Airflow? Check. Spark? Check. Fuses? Check. Fuel? Hmmm. Ok maybe it's the inner tank fuel filter. Change fuel filters and pump. Fuel flowing? check. Same symptoms. Hmmmmm
Anyone have any ideas? I've been chasing this gremlin for two seasons now. Help?
