Help 1994 Sea-Doo won't run
bgbmomof5
For some reason I can't post public. So private will have to do. Have a 1994 Sea-Doo. Took to the shop, they worked on it took it to the lake and ran it for 30 minutes. Yesterday, I put it in the water and as usual it ran for 30 minutes or so and quit. Quits like it is not getting gas. Is there a sensor that would cause shutting off if there was a leak. Does not smell flooded but it won't run for long. Thanks for any advise you can offer.
You are in the public forum...PM, or "Private messages" are not seen except for the member you send it to.
I suggest you check the fuel tank vent. If it happens again open the fuel filler cap and see if it has a vacuum. If it does and it now starts up, check the vent line going to the fuel tank.
Karl
Not a problem, if you still have questions give us a shout. This is a friendly place with lots of active members eager to help out.
Karl
