GTX RFI 1999 Fuel problem
tackleshep
Ok just killed my other thread, I'm pretty sure I know where the problem is hoping you guys can tell me the extent to which I need to fix it.
Had this 1999 that wouldn't start. When I pulled the fuel line I had fuel coming out so I didn't think that was the problem. Pulled the fuel pump out of the tank and was going to drain the fuel tank and replace the filters when I got the brilliant idea to do the same test on the sister ski (yeah real brilliant huh) well when I pull it's fuel line and plug the key in the sucker shoots gas all over the place not the trickle I got in the other.
So since compression and spark are both great I'm figuring this is the problem. I think i hear the pump running but before I drop $400 on a new pump does anybody have any ideas of other problems that could cause the fuel not to pump.
Thanks
