I usually find all of my answers by searching the forum but I can't find anything on this issue. On a 2002 GTX DI, it starts and idles fine and after about two hours of running great this past weekend, it began to shut off if you go over 30 mph, (4800 rpm.) It never beeps or gives any warning info, it just stops. It will start right back up, and ride fine if you keep your speed down. I checked compression, charging status (all good) and looked for any suspect connections. Fuel is fresh and over half-full. Oil is over half-full. And when I say it stops, I mean it's like you pulled the D.E.S.S. off. What should I check next? Or am I off to the stealership?
