GTX 260 IS LIMITED engine problem
Mark06208
Hello,
I Have a 2013 GTX 260 IS Limited with about 50HRS. was riding it the other day and engine shut off at speed and I restarted it and it sounded Horrible and smoke came out the back. Does this sound like a Supercharger problem, Piston rings, rod bearings? I shut it down and towed it back only ran about 3 sec. Any suggestions would help. Thanks
With information given no definitive answer can be given. The engine should be checked over. Check oil level. If oil level is ok remove air intake and feel inside supercharger to see if it is lose or you can turn by hand. If that is ok check compression. compression and while engine is turning over listen for any noises.
Replace spark plugs and do a compression check at the same time
Check oil level first of and coolant level also confirm no fault codes
Then gives us a feed back
