(Posted this originally in the boat section, rookie mistake, thank you Alainm for the help)
Greetings all, do not post very much at all but spend loads of time gathering info. I have a question that I cannot seem to find a consistent answer for. I am looking for the stock pitch size for the impeller on a 2007 GTI SE 155. I purchased it about a month ago and thanks to this site have changed the oil and filter, changed the coolant, replaced the spark plugs, change the OPAS rubber tubes (yes, I am going to keep it} and replaced the wear ring. It runs great with no issues. Had nothing but 2 strokes prior to this one, ( 2002 RXDI, 2001 GTI, 95 GTI, 94 GTI and a 1993 SPX ) Still have the RXDI, what a great ski! Also have the 2001 GTI.
When replacing the wear ring it appears that the impeller may not be stock. It is a tad beat up so would like to replace with a different one and a stock pitch one. I have searched all over the place and cannot find a consistent answer to what is the stock pitch impeller. Part # 267000675 I can find a replacements but no one seems to know what pitch it is. I have gotten responses that are 10/18, 11/21 10/21 and even a 12/21. Not looking for an upgrade or aftermarket unless it is the stock pitch. Will most likely buy a used one and clean it up a bit. A new one seems a bit expensive!! But leaving my options open.
Any help in determining the stock pitch would be greatly appreciated!
