GTI Engine Turns Over But No Spark
Jkwarciak
Its a 1999 Sea Doo GTI.
The key beeps twice as it should when inserted. The engine turns over and sounds exactly how it should but there is no spark - it will not fire up. Its losing volts somewhere.
The magneto, battery and computer were just replaced in hopes of that being the issue, but was not. I believe there are new, if not newer spark plugs.
The white wire going to the coil in the Cdi box next to the battery is not showing any volts. We compared it to the other ski thats running which does show volts at that wire. When we cranked my jet ski, the volts would continue to drop at the white wire - It was checked on both computers (new and old - same result).
Any ideas what it could potentially be / how to fix it? Any help is appreciated. Thank you!
