gsx ltd 1999 engine runs irregularly
KevinPenhaligon
my engine will start up an run at low speeds but doesn't sound right. wen u open the throttle it makes alot of noize but doesnt seem to rev past a serton point.
can any help :(
Check the wear ring clearance on the impeller. It sounds like it needs replacement.It should be .040" at the center of the impeller blade.
Karl
pull and clean the raves, does it have grey fuel lines, if..need to replace them, and along w/ that, should clean/replace the fuel selector valve(on/off/reserve switch) and go thru the carbs.
