TomShadow
So I've just fitted a new throttle cable as it seemed to be sticky last time I was out and not sure how old it is.
What should the ski be idling at? And what's the best way to adjust it. I appreciate the exhaust will have to come off but how do the test the idle if you have to replace the exhaust ever time you adjust which isn't the quickest of jobs
I'm also getting a low oil warning but there's plenty of oil in the tank. The ski has been sat for 2 weeks and I've just found quite a bit of oil sitting in the hull. I'm wonder if the wheel the 2 cables go into might be sticky and not spring back properly
