buttonbash2shop
Hi and thanks in advance for any help
Ski was running great then after a rest it went great up to WOT and then started bogging down power loss
and if you work throttle as its doing it it makes no change then if you let it idle it will go great to WOT for about 5 secs and then bogging again never cut out at all seems like it running out of electrical power
as we changed the plugs while on water made no difference
got it home and checked fuel filter all good and i removed the kill switch (one of those red key ones) that previous owner had put on Has new battery
will have to go for water test
but is there anything else i should check before driving 30 mins to find its the same
