I have replaced my main ground cable running from the battery to the engine case on a 2002 Seadoo Gtx 4 Tec as the old cable was getting red hot and in bad condition, went for a run today for about 1 1/2 hours and the new cable insulation is melting at points, I did not use an original Seadoo cable but used what I thought was a heavy duty cable.
Can anyone say what current this cable would have running through it to get so hot, I cleaned all the connections/terminals, upon inspection of the 2 smaller ground cables coonected to the battery they are both black inside the cable.
If someone can help I would be greatful.
I also blew a seal on the propulsion shaft but its going to a local workshop for that.
