I was driving my PWC on a long flat inland waterway at almost full throttle when I lost all electronics and the motor died. It would not start up right away, and after a few minutes, and taking the lanyard off, it chirpped chirpped and started. I thought I had ingested seaweed, but that was not the case. The PWC than ran normally, at idle while I made my way through the channels out to the large Lake. I ran the boat like it was meant to, hard, soft, turns, etc. for about an hour without any other problems. Then all of a sudden, it did the same thing again. I could only get it to start by taking the laynard off then put back on to get the chirp chirp. It would not start by just leaving it on. I did get it back to the dock, but had to go at idle speed the whole way, because everytime after, it would not let me power up any more than about 2000 RPM's.
I wonder if I am having electrical problems because the electronics shut down. I have not found any reason for that. Everything electrical is tight and no water or condensation has gotten into it.
I then wonder if I have bad spark plugs or there is something else wrong. Could bad spark plugs shut the whole boat down like that?
If anyone else has had this problem, please advise what you did to solve it. I am quite mechanical, and would rather do it myself than take it to the dealer.
