andy.262
So I'm taking apart the engine down to the crank, as recommended on this forum after my RAVE valves and pistons blew apart and got chunks of metal all in there. I have a few questions now that I'm in the process of actually taking it apart.
1. Will I need new outer crank seals? I'm thinking even if I don't need them I should probably just replace them anyways while I'm in there...
2. There's an old SBT video of a tech taking off the PTO flywheel with a chain wrench. Is that really the best way to do it? The flywheel looks kind of thin to be able to fit a chain wrench around, but it might be possible.
3. Once I get the crankcase split, how do I "clean it out"? I'm assuming I shouldn't use water, so maybe carb cleaner? 2-stroke oil?
4. For the mag flywheel, I've gotten this far before realizing I need the special puller to actually get it off. Once I get the puller, does it matter the orientation of the wheel relative to the crankshaft? This is related to the timing, yes?
This is the 787 engine out of a 97 SPX, if that helps. I assume it's very similar for most of these engine though.
