Gas put in Oil in Spark
Well,,,the oil will be very thin and easy to extract,,,don’t start it up to warm and thin the oil.,,,fill it…run it for a minute,,,and then do 1 more extraction,,,it is impossible to get drop of oil out…use thicker oil than normally advised to compensate for the thinning properties of the gas,,,replace the oil filter,,
yea i got it out fairly easy. put my expensive amsoil into it and ran it and then drained it again. hopefully that does the trick. Thanks!
I always save our used oil for submerge cases,,,oil is so expensive,,,do the extraction and first refill with free used oil,,,then put in the good stuff…just once.
