I'm most of the way through replacing the fuel lines on a 2001 xp but I broke the check valve (p/n 275500505) that is located on the vent line that leads to the side wall on the left side of the xp. I order one but it wont be in until next week. I also have a 2000 and a 1999 xp that I'm using for parts as needed (the engines are shot). Both these machine have a check valve in same location, but it looks slightly different. This check valve part number for the '99 and 2000 is is p/n 275500416. Does anyone know if I can use the check valve from the 2000 until the correct one comes in?
Any and all help is appreciated.
Thank you.
-john
Thank you.
-john
