Z zgentile New Member Oct 3, 2019 #1 I was wondering if someone could help me out I took pictures before taking the carbs off and I can’t tell where this last line connects to.
Z zgentile New Member Oct 3, 2019 #2 These are the pictures Attachments 70D26638-36D4-4C4C-B862-6FDF929222B8.jpeg 2.7 MB · Views: 20 2A273D0C-907E-469C-9748-556CA94A6D7D.jpeg 3.8 MB · Views: 20
mikidymac Moderator Staff member Moderator Oct 3, 2019 #3 Should be under the front carb. I hope you are replacing fuel lines and zipties? Those are not the correct ipties to use. Also your oil injection oil looks really dark, what are you using?
Z zgentile New Member Oct 3, 2019 #4 mikidymac said: Should be under the front carb. I hope you are replacing fuel lines and zipties? Those are not the correct ipties to use. Also your oil injection oil looks really dark, what are you using? Click to expand... mikidymac said: Should be under the front carb. I hope you are replacing fuel lines and zipties? Those are not the correct ipties to use. Also your oil injection oil looks really dark, what are you using? Click to expand... yes I just bought this and it seems as if they started to change the lines and then gave up i ordered all new correct zip ties i am going to check now to see if there is a place for that fuel line to attach to thank you
