Fuel line in 96 XP
Donxp96
hi, i just bough a 96 xp about two week ago, found out it had water in the engine so i took out the plugs and cranked most of the water out, now it started again, so i decided to replace the gray fuel line and clean out the carb. my question is kidda silly: How do i get the fuel to flow in these new line? Do i just keep cranking the motor until the pump suck the fuel through or what should i do? i know boat have primer bulb but these don't. Thank you for all the help.
fuel lines
Hold the choke, while cranking, it will suck the fuel through in no time.
I replaced all lines, and the fuel filter assembly, it fills fast.
