fuel guage problems
avi8or3117
Both the fuel gauge on my 98 SPX and my 2000 GTX are not working. What normally causes this to happen? Is it a sensor that I can replace or could it be the gauge itself? Are the gauges normally pretty reliable? Is their a way to test them so that I can isolate the problem and fix it?
Thanks
Well, in order to eliminate the gauge as the failure point you can test it by unplugging the wires coming from the fuel baffle to the wire harness with which they connect. Stick a paper clip in the wire harness running off to the gauge to close the loop, push your start button (without key on post) to activate your gauges. The Fuel gauge should read full, if it is not, your gauge is bad.
Assuming your gauge is ok, there are typically three other issues that would be causing your problem.
  1. Your magnet has fallen off the fuel float
  2. The fuel float has absorbed fuel and no longer floats
  3. A small fuse inside the baffle has blown
You will have to remove the baffle to fix any of these issues.
If the magnet has fallen off, you can fish it out with another magnet and reattach to the float. Use a dab of some sealant/adhesive that is not soluable in fuel to keep it in place if necessary. The magnet is what the fuel baffle senses the location of in order to read the fuel level.
If the float no longer floats in gasoline, replace it (~$10-$15). The float holds the magnet.
If everything else is ok, then your fuse must be blown. You can fix it by bypassing the fuse (soldering the gap..I don't exactly like this idea) or finding a suitable replacement fuse to solder in there. In order to do this you will need to cut open the baffle. Google "Seadoo fuel baffle fuse fix", that should get you some insight as to how to do this. Alternatively, you can get a used/new baffle for roughly $80-$160.
both
both my '02 and '98's did this this year... SAME summer!!! what the heck?!
With all the work to pull / replace the baffle. I didn't want to do it 2x
So I ordered all new parts, and just put them in.
both fixed.
The gauges are reliable, the fuel baffle and it's components are not. This is a very common problem with seadoos. Mine is currently broken as well. I just drained my tank last night to start the process of getting the baffle out. :(
No need to drain the fuel to get these out...unless it was completely full.
Well...yes, sometimes you actually do have to drain the fuel tank. I have a 98 GSX Limited. The only way to get the fuel baffle out is to move the entire gas tank forward and pull it through the steering "hole". I have to take my handlebars off (and even removed the MPEM to allow more movement of the tank). Even with a few gallons in the tank, it makes moving the tank VERY hard as there is not much room to maneuver it.
:rolleyes:
Ahhh....but yours is a different model. The GTX and SPX fuel cell and/or baffles are a different setup. Apples and oranges to the GSXL.
Steps
Before removing fuel baffle lines, unscrew the gas cap to vent the tank.
else you shoot gasoline 3 feet in the air and in your nose and eyes.
it was not fun. vent the tank.
