Installing the front bumper on a 2013 Wake Pro
It has 5 10mm hex bolts - easy to remove. Three bolts under the hull and one on each side behind the caps. To install, push the bumper tight to the hull and install the front ones first. Then the sides. Make sure you don't lose the caps in the water. The hex bolts are aluminum with an integrated washer. If you banged into something...assume the screws could be bent so order some new ones to be safe.
