water_scooter_joe
Can I even get to the flush port with IBR?
I would need to take out the venturi to install a flush kit, correct?
Do I need to take out the venturi to attach the flush kit?IBR is not in the way. It would be difficult to attach the hose directly, so an adapter is recommended to connect the hose to the flush port.
I have that and a service/shop manual.You do not need to take anything apart, or cover anything. I highly recommend you get an operators manual and just read through it.
There is no screw in for the water hose. There is a nipple all the way in the back. This allows you to push on the rubber 1/2" OD tube then mount that to the frame with the quick connect.There are no mounting screws? All that’s needed is an adapter that screws in on the starboard port. No tools required
so let’s make this clear. Are you installing this?Or just trying to flush they system? There are screw in adapters for 15 dollars that don’t require any modifications. If you are installing that yes, you would have to take off bucket and IBR components.
Have you seen the flush port on a '14 sea doo spark?So that is going to fit over the nipple? Your still going to need a short tube to make that adapter work.
Ok. Do you see now what I am talking about?I’m looking at the install instructions from BRP for the flush port. I think you should look too.
Yes. And have you looked at the BRP instructions? Answers all of your questions.Have you seen the flush port on a '14 sea doo spark?
Fabricating my own. That kit is not worth the price tag.Are you installing this flush kit or fabricating your own? That will definitely clear up any ambiguity.
