rotaxrule1
Hi guys,
Well here is another water flooding story. Last Sunday I took our machines out for a run and during the process of someone getting on my 96 xp, it tipped over. After that it would not start.
So, I turned it over a few times. At first it fired, quit, fired, quit. I pulled the plugs and light water mist on them. I figure it must have had water from the exhaust back flush inside when it tipped the wrong way. ( sound correct?)
Anyway, right away I started with the cranking with plugs out, let the plugs dry in the sun for a sec, put them back in, crank over again. I repeated this process on the water about 15 times until it killed my battery and my wife towed me in.
Got it back to the dock and jumped it from my gsx (not running) tried a few more times, plugs were finally looking dry. At which point it fired up. I let it idle at the dock for a few minutes, then took it out and ran it for at least ten minutes until I had to leave. Then when I got it on the trailer and was waiting for the others to come, I let it idle some more there (about 5 mins)
That being said, I just have 2 questions for you guys if i may:
1. Would you say I did my due diligence for getting the engine dried out and safe?
2. During this last few minutes, my gas guage also acted weird. It was indicating full ( correct reading) then all the sudden the bars started gradually going down as if gas was draining (tank was still full) did the sending unit die on me or could that be due to the battery being so low? I have it on the charger and will try it again after I charge it.
Sorry for the long posting, thanks so much as always for any help
