So finally for my 2004 GTX 4tec 155 on the water after getting it running and when you hit the throttle the rpms jump way up and you can hear the rpms limiting
Here is a quick video where you can hear it.
Quick Share
Seems to to better once it's on plane .
When running out of the water with a water hose the rpms will instantly jump up to max at only about 10 or 15 percent throttle .
In the water it will max out rpms until it gets going
I looked at the wear ring thru the back nozzle and there doesn't seem to be much of a gap
Quick Share
