AKnarrowback
I had some friends of my Cousin give me their 97 GTX a couple of weeks ago. It has 97 hours on it, is in near perfect condition, runs as good as the day it was pulled from the crate, but has a failing RV resevoir seal on the crankshaft so it smokes a bit when you first start it.
Today was the first chance to take it out. Water temp was 44F, air was 52F, sunny with yellow leaves on the trees and Geese flying south overhead.
I see what everyone is talking about with the 3k to 4500 stumble in these machines. It's interesting how the carbed, rave equiped motors in PWC's react the way they do when compared to how smooth the rave valves transition on the carbed snowmobiles. With so many more variables in clutching, gearing, altitude and air density that a sled can encounter it seems like the lack of fine tuning that can be done in the PWC carb is one main contributor to this stumble. There are so many more components in a Mikuni round slide that can tune out running problems.
Does anyone know the rpm range where the 787 motor is designed to transition from a low port to high port? What rpm the carb transitions (roughly)? What rpm the water valve is supposed to operate at? Many overlaping actions, there has to be a way to smooth things out a little. The rave transition rpm on sleds is higher than it is on PWC's, what will it hurt to increase rave spring tension to delay the transition until after the carbs have moved further into the high speed circuit? Lots of carb theory - vs - engine rpm can be applied here. Things were engineered to prevent burn downs, but the engineering was also done to accomodate a wide range of riding styles. Too bad the season is almost over, I really want to go experiment on this......
Anyhow, it was an awesome ride until I came back up river to the park/launch area where a group of people were standing in a half circle on the grassy river bank, playing an acoustic guitar, some were holding a single flower. I thought "hippies" and parked my Doo about 75 feet down stream, backed the trailer in and loaded my ride. The tie down strap for the machine had fallen in the water so I hopped off and reached in to retrieve it, and noticed a flower float by next to me, then another flower and a strange looking, grayish, pollen looking something floating on the water all around me. I looked around and see the people up stream, one at a time, reaching into a big zip lock bag full of dust, take a hand full and throw it into the river.....
They were spreading the ashes of someone..... well...... being a man of God I did what I thought would be best at the moment, I said a short prayer, unloaded my ride, found some clean water, washed myself and the Doo clean, waited for the ceremony to end, loaded up, waived good by to those watching and left. Mark that one up to "akward moments"......
