Probably a little under half I have one of those manual oil pump so how would I get the oil out the engine?
Thanks for taking the time and explaining it I really do appreciate it thank youWell a pump will definitely help. Pump as most of the oil out of the tank that you can. Put an old shirt in the hull to catch any oil that spills and then unhook only 1 of the rotary valve bath hoses from the tank and put the pump suction tube in it and take out as much oil as possible. After that you'll have to just lay down the oil line in the hull and drain it into the rag. You'll probably also have to remove the oil injection line from the tank and drain that too. Remove the oil tank, flush it with HOT water and let it dry. Not a bad idea to replace the oil lines at this point as they're probably original. Hook everything back up, Fill oil tank with SEA DOO MINERAL OIL from the dealer and make darn sure you bleed the oil pump to get any air out per the manual. If you want to clean the hull up really well I personally use the Purple Power in a spray bottle and spray the inside of the hull a good bit. Don't use a pressure washer! No need to, the hot water is best. Take a garden hose and hook it up to the bottom port of your hot water tank, turn the valve and lightly spray the inside of the hull for 5 minutes and it will look like brand new. It will be so clean if you ever have any kind of gas or oil leak you'll see it right away.
Maaaaannnnn
You think i can use it then with no problemThe full synthetic shouldn't hurt it, it's just not needed
Yes you're fine with that oil, full synthetic is definitely better but not "needed"What
So I found your reply among all the highjacking of my thread and want to discuss the pressure regulator. How often do these go bad? Do you happen to have a part number? I found the bosch pump and will order it shortly.Bosch Fuel Pump. I got lucky and never had to test the fuel injectors on either ski as I figured out the fuel pumps were bad first by checking the pressure. Both fuel pumps DID work, but they were low on pressure. The DI also had a bad fuel pressure regulator on the fuel rail as well. I think the RFI pressure regulator is on the top of the fuel tank - built in. There is a kit on there from the same seller for $95 with the fuel pump and a pressure regulator but their listing doesn't show what it fits. They say to check their compatibility chart but I can't find it in either listing. These may not be the right ones as the listings read 3 bar which is about 43 psi which is too low. The pump only listing does have the Sea Doo part number though - MARINE KIT 1 BOSCH FUEL PUMP FOR SEADOO 270600003 FOR GTX RFI
Maaaaannnnn
No, not yet. I have the injectors out getting checked and reconditioned. When those get back, I'll either A) check the fuel pressure or B) spend the 40 bucks for a new Bosch one and not worry about it for (hipefully) 250 more hours and 13 years. After that, I'll give her a go and see if she'll start. If that doesn't work out, I have a friend who has offered to help me with it and he has all the crap to work on an RFI.I've only worked on a handful of DI's and RFI's. 1 was bad in the DI. I looked on the parts fiche and they don't show a number just for the pressure regulator. Did you check the fuel pressure yet?
So that e-tec oil will be ok then ?xps full synthetic 2-Stroke is applicable for any 2-stroke seadoo, some don't require or need it. this formulation is also fine for pre-mixing and any air-cooled 2-stroke.
I use this product in my 2-stroke chainsaws and weed eaters for years now with no ill effects. The only 2-stroke I would advise against using xps-2 full synthetic in is outboards or anything specifying TCW-3 (Hydrazine type detergent package).
Do you have an E-TEC engine? No you don't. Do you have an RFI or DI injected engine? No you don't. Do you have a RAVE Valve engine? No you don't.. That is the wrong oil but it will work, but then again so will Super tech TCW3 from Walmart. Both wrong oils but both will work... For a while. CALL THE DEALER if you can't look it up yourself. Sea Doo NON RAVE Valve engines should use the Sea Doo Mineral oil ONLY. Just because the oil is from Sea Doo and more expensive doesn't mean it's the right oil...
Yes that oil is 100% absolutely fine. Honestly you couldn’t have picked a better one.
