Flying96XP
I know i posted almost the same thing in the X-4 thread but i figured i'd throw it out on the main forum as well. I'm having issues with my head pipe coming loose 3-5 minutes into riding on my 96 XP. I've been through a broken pipe and a few gaskets now. Per some advice i inspected the the mounts and found the rubbers cut up and smashed. I ordered all new mounting hardware and yet another gasket. So my questions are...
1. Is there a washer on both sides of the mount bushings or just the bolt side. Parts image shows just bolt side.
2. what is the best way to sequence the bolts (loosely install all then head-pipe to cone pipe to the mounts on motor to the mounts in pipe?)
3. Locktite? yes or no? red or blue?
4. I just installed a new copper washer between the head and cone pipes with the red high temp silicone. should i replace that again also or should that be fine to reuse?
Thanks for the help!
