Fault Code P0524 on 2012 RXP-X
badfish
Just changed my oil (first oil change, 20 hours) on my 2012 RXP-X and when I started it I got a check engine light. Fault code is P0524 which, as far as I can tell, means low oil pressure. I checked the dip stick and it is right in the middle. When I changed the oil I took out 3 qts. and I put back in the same (Amsoil 4 Stroke Marine). Using a K&N oil filter.
Any ideas on this? I am about to call the dealer but I am trying to check around before I do that. They are going to tell me to bring it in so they can change the oil and rape my wallet.
Thanks for any advice you can offer!
Badfish
Just got back from the dealer. They cleared the code and the check engine light went away. There was also a cluster update available. He installed and all is good.
