I recently bought two 2020 GTI 130 PRO. When I bought the jet skis one of them did not have a TOPS switch and I was getting Fault Codes P1505 and P1506. I installed a new TOPS switch and Fault Code P1506 went way but P1505 is still there. I put it in exact like the other 2020 GTI is installed and I tried to clean the connection and I'm still getting the P1505 fault code. Any suggestions on what it could be or if anyone has away to fix the issue. I would even take any info on how to bypass the TOPS switch. Thank you
