About 1,000 ft before the end of a long open-water stretch, the pump took in water and lost the bearings and other "guts" into the ocean. The pressure from the impeller forced the drive shaft toward the engine and unsealed the carbon ring seal. Water flooded into the hull and to make a long story short, it choked on salt water. The thing that killed it was continuing to ride it a bit with water in the engine which caused the oil to mix improperly. The inner engine "bearings" failed, spreading metal debris in the engine. Then it was dead. The good news is a marine mechanic bought it and rebuilt the engine, so I guess it was "reborn". He changed the seat, though, so it didn't quite look the same after that.
