Got a barely used 2001 Sea-Doo Challenger last year from my father who stopped using it after a few years owning it. It sat for a few years so I had the fuel system cleaned, after which it was running well. Just started using it this year. Was running well until yesterday, 3rd time out this year. It ran well for a few hours. Then the port engine stalled, but started up again and ran ok. About another hour and the starboard engine did the same thing. It wouldn't re-start. The port engine was now also not running well, surging between 4000-5500 rpm.
Limped back to the ramp like that. Before getting back I was able to get the port engine started but it wouldn't turn more than 2500 rpm. After getting back I pulled the boat out. There was a lot of water in the bilge which I drained. I think the bilge pump isn't working, another problem.
After draining the water, I briefly started each engine. This time the port engine started right up, but the starboard was balky. Finally it started.
After getting home I hooked up a hose and started them again. Each engine started quickly (port faster than starboard) and seemed to run well out of the water. Of course, it never runs more than 3500rpm when no load. Could it be ok now?
I once remember something similar happening before my father stopped using the boat. It was repaired and the shop said there was water in the carburetors.
Is that it? How do you prevent it from happening if so? I read some postings say the carbs need to be cleaned or rebuilt after similar symptoms were experienced.
There's a lot of discussion about the crappy gasohol we're forced to buy due to our corrupt congress and corn processors...ok not the place for that rant. Most say get some Sta-Bil or similar. Might that do the trick? Or do I need to pull carbs?
