TarHeel Challenger
Check this out,
So I enjoyed a great day at the lake today, boat ran great (even though I forgot to put in the drain plug) bilge worked great, spend several hours out. I get the boat out of the water, not a drop in it, which was awesome, and I started to the engines out of the water, to blow the little the was left in there. Turn on, one to two seconds turn off, i do the same with the right side engine, and I turn it on, one, two, pull the plug, ITS STILL RUNNING, I turn the back of the boat, and pull the spark plugs, still running, I pull the wiring harness that meets the the battery with the spark plugs and stuff, still running, not at a high speed, but a little higher than a idle, and it just slowly dies out, doesn't pop, like its blowing but more like running out of fuel. Not much smoke, a little, and didn't smell at all. I tried to start it, fires right up! Turned right off.
I don't get it???!!!! WHAT HAPPENED ??? a gas build up in the carbs, engine was just running so it would be able to burn it off. thats the only thing i can think of. Going out again tomorrow, going to look at it in the morning. Let me know if you got any ideas because I am freaked out.
