A adamzpop Member Mar 28, 2010 #1 I just got my hands on a '95 GTX (657x)with a blown motor. I also have a perfectly good 717 motor sitting in my shed.My question is,will the 717 work with the MPEM in the GTX? Any help would be much appreciated. Thanks
Dr Honda Well-Known Member Mar 28, 2010 #2 As far as I know... it will bolt in. But let me double check the ignition stuff.
Dr Honda Well-Known Member Mar 28, 2010 #3 Yes... the wiring is the same. I would use the CDI/coil from the 720 after the swap, but otherwise... it will work.
Bills86e Premium Member Premium Member Mar 30, 2010 #5 The jetting is different, hopefully you have carb(s) on the 717. Electric works both.
A adamzpop Member Mar 30, 2010 #6 I have the carbs for the 717...I'll give it a go. Thanks for your help
