bigtexan99
Two new issues have developed with my 2003 Sportster LE (carb) boat. It did not run much in the last year. Just finished a driveline rebuild on it.
It has new gas, and is pre-mixed, the oil pump was removed a few years ago. I cleaned and reinstalled the raves. Spark plugs look okay, maybe a little oily but the engine starts up very easy. Fuel filter was removed and cleaned, was not terribly dirty.
Issue number 1: Ever since I got the boat, it randomly cuts out at high speed. I can be cruising along at at 5-6k rpms and then it just shuts off like if the kill switch was pressed. Originally, it was pretty uncommon, I might drive continuously for 15 mins at 85% throttle and then for no apparent reason it cuts out. Recently, the cut outs have been happening much more frequently, and today it was only able to run for about 15 seconds before cutting out. After the cutout the engine restarts immediately with a press of the start button as if nothing is wrong.
Issue number 2: Engine bogs and dies when trying to accelerate from idle to full speed. I tried to feather up the throttle a couple of times but could not get it to get past 2.5rpm, it stumbles bogs and dies. I did find that while idling if I pull the choke full open for a half second and release while simultaneously advancing the throttle I can overcome the bogging and the engine revs up to speed but then Issue Number 1 takes over and it cuts out around 5500 rpm.
I've attached a video of the throttle up and engine cut out, but its not the best video. https://drive.google.com/file/d/0B3YepRZPJ3nLT2RtTThMdnIza3M/view?usp=sharing
Help!
Help!
