Kevin akin
I have a 2004 seadoo gtx supercharged that i was checking compression on for reference and also put in new plugs. I put in drown mode to do compression check after i finished what i was going to now wont start. fuel pump is not kicking on. I put gas in cylinders and it fired up. I have 12 volts going to fuel pump when key is applied with test light. ground was used from battery. put have no ground working going to fuel pump from ecu. it started and ran before i did what i did. how to i get it out of drowned mode if its still in it. I have tried disconnecting battery. taking plug wires off and holding start/stop button for ten plus seconds with no effect. Has this happened to any one else .
